Einleitung
Use this guide if you want to upgrade the processor inside your HP Pavilion x360 m3-u101dx laptop to improve the performance.
The processor is what runs your laptop, and it is one of the most vital parts to all computers. Slow performance of a computer can sometimes be caused by a faulty processor, which is very difficult to repair on your own.
Was du brauchst
Flip the laptop over so that the bottom of the laptop is facing up.
Remove the rubber grip using a plastic opening tool.
Remove five 1.7mm Phillips #1 screws.
Lift open the laptop screen and flip it around so that the keyboard is facing up.
Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
Detach the keyboard panel from the frame.
Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
Remove the keyboard panel from the rest of the laptop.
Use a plastic opening tool to lift the battery cable out from the motherboard.
Disconnect the seven ribbon cables connected to the motherboard using a finger or plastic opening tool.
Remove the ten 1.2mm Phillips #1 screws that hold the motherboard into the frame of the laptop.
Ein Kommentar
Thank you! Very helpful guide. After following all the steps, finally i have replaced my laptop processor. Thanks
You can also check: '''How to Make a Laptop Faster'''
