Zum Hauptinhalt wechseln
HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement
Was du brauchst
  1. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power off Device.
    • Working device while it is powered on may cause damage to laptop or electric shock.
  2. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip over laptop
    • Remove the rubber foot with a Metal Spudger
  3. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws.
    • 5 Phillips 2.0 x 5.0 mm screws.
    • Make sure to keep different screw types separated.
  4. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Flip the laptop over to screen and keyboard side.
    • Using a Metal Spudger pop open keyboard from base of laptop.
    • Be cautious of three wires on the inside of the keyboard connecting it to the motherboard.
  5. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
  6. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 6, Bild 1 von 2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: Schritt 6, Bild 2 von 2
    • After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
k.kolish2493 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 29
Insgesamt: 781
