Einleitung
In this guide you will be required to remove the keyboard and disconnect three wires from the device in order to replace the keyboard. You will need to use a iFixit Pro Tech Toolkit.
This task requires patience and attention to detail.
Was du brauchst
Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
5 Phillips 2.4 x 5.7 mm screws.
5 Phillips 2.0 x 5.0 mm screws.
Flip the laptop over to screen and keyboard side.
Using a Metal Spudger pop open keyboard from base of laptop.
Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
