Einleitung
These steps will allow you to remove your CD/Optical drive with ease.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the 8mm Philips screw located between the hard drive and the WiFi card.
Turn the laptop 90 degrees clockwise so you are facing the CD drive.
Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
Gently pull the tray away from the laptop and the rest of the optical drive will follow.
Ein weiterer Nutzer hat diese Anleitung absolviert.
