Zum Hauptinhalt wechseln
  1. Slide the battery release latch towards you.
    • Slide the battery release latch towards you.
  2. Pull up on the battery to remove it. Pull up on the battery to remove it.
    • Pull up on the battery to remove it.
  3. Loosen the Phillips screw labeled ‘ram’ and lift the cover. Loosen the Phillips screw labeled ‘ram’ and lift the cover.
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. Locate the green RAM card and find the metal tabs securing the card. Push outwards on the two tabs to release the card.
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. Carefully slide the card out at an upward angle away from the slot.
    • Carefully slide the card out at an upward angle away from the slot.
  6. Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs. Lift the cover from the right to remove it.
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  7. Use tweezers to detach the grey and black cables connected to the green WiFi card. Use tweezers to detach the grey and black cables connected to the green WiFi card.
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  8. Remove the 8mm Philips screw located between the hard drive and the WiFi card.
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  9. Turn the laptop 90 degrees clockwise so you are facing the CD drive. Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  10. Gently pull the tray away from the laptop and the rest of the optical drive will follow. Gently pull the tray away from the laptop and the rest of the optical drive will follow.
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
  11. Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  12. Flip the laptop over and open the screen. Push up on the four latches located at the top of the keyboard with the spudger to release them.
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  13. Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable. Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  14. Rotate the keyboard so that the bottom is visible. With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  15. Place the laptop face-down and rotate it 180 degrees so the vents are facing you. Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  16. Flip the laptop over.
    • Flip the laptop over.
    • Fully open the laptop.
  17. Rotate it so the display is on your right and the keyboard is on your left. Lift the switch cover firmly but slowly so you do not snap it. Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  18. Close the lid and rotate the laptop so that the vents are facing you. Unscrew the two 8mm Philips screws below the hinges.
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  19. Carefully rotate the laptop 90 degrees counter-clockwise and open the screen. Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  20. Using tweezers, remove the black cable from the hole leading to the WiFi enclosure. Pull gently to remove the black and grey cables from the case.
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  21. Using tweezers, pull the black cable towards the display and through the hole in the casing. Using tweezers, pull the black cable towards the display and through the hole in the casing.
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  22. Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display. Lift the screen upwards to detach it from the laptop. Lift the screen upwards to detach it from the laptop.
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
  23. With the laptop face-down, remove the eleven 8mm Philips screws. With the laptop face-down, remove the eleven 8mm Philips screws.
    • With the laptop face-down, remove the eleven 8mm Philips screws.
  24. Rotate the laptop 180 degrees so the vents are facing you. Unscrew the four 3mm Philips screws below the vents.
    • Rotate the laptop 180 degrees so the vents are facing you.
    • Unscrew the four 3mm Philips screws below the vents.
  25. Rotate the laptop 90 degrees counter-clockwise. Unscrew the two 3mm Philips screws from the optical drive bay.
    • Rotate the laptop 90 degrees counter-clockwise.
    • Unscrew the two 3mm Philips screws from the optical drive bay.
  26. Flip the laptop over so it is face-up with the trackpad closest to you. Locate the ribbon cable directly above the track pad. Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
    • Flip the laptop over so it is face-up with the trackpad closest to you.
    • Locate the ribbon cable directly above the track pad.
    • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
  27. Find the ribbon cable on the LED board located at the top of the laptop. You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level. Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
    • Find the ribbon cable on the LED board located at the top of the laptop.
    • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
  28. Locate the white connector attached to a red and black cable to the right of the LED board. Using tweezers, pull the white connector away from you.
    • Locate the white connector attached to a red and black cable to the right of the LED board.
    • Using tweezers, pull the white connector away from you.
  29. Unscrew the four 8mm Philips screws from the top cover. Unscrew the four 8mm Philips screws from the top cover.
    • Unscrew the four 8mm Philips screws from the top cover.
  30. Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader. While lifting the front end of the top cover, slide the spudger across the seam.
    • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
    • While lifting the front end of the top cover, slide the spudger across the seam.
    • When you have reached the firewire port, it should click open.
  31. Lift the top cover from the left side to remove it completely.
    • Lift the top cover from the left side to remove it completely.
  32. Rotate the laptop 90 degrees counter-clockwise Locate the USB Module
    • Locate the USB Module
    • Grip the yellow cable cover and pull it to the right to release it.
  33. Unscrew the 6mm Philips screw connecting the USB module to the fan. Unscrew the 6mm Philips screw connecting the USB module to the fan.
    • Unscrew the 6mm Philips screw connecting the USB module to the fan.
  34. Pull the module to the right and lift it out to release it.
    • Pull the module to the right and lift it out to release it.
  35. Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon. Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
    • Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
  36. Unscrew and remove the two 8mm Philips screws from the heat sink fan.
    • Unscrew and remove the two 8mm Philips screws from the heat sink fan.
  37. Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
    • Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
    • Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
  38. Using tweezers, remove the left speaker cable by pulling the white connector towards you. Using tweezers, remove the left speaker cable by pulling the white connector towards you.
    • Using tweezers, remove the left speaker cable by pulling the white connector towards you.
  39. Remove the LED board cable by pulling the white tab towards you. Remove the LED board cable by pulling the white tab towards you.
    • Remove the LED board cable by pulling the white tab towards you.
  40. Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you. Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
    • Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
  41. Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard. Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you. Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
    • Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
    • Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
  42. Using tweezers, pull up on the Bluetooth module to remove it. Using tweezers, pull up on the Bluetooth module to remove it.
    • Using tweezers, pull up on the Bluetooth module to remove it.
  43. Remove the fan cable by pulling the white connector away from you. Remove the fan cable by pulling the white connector away from you.
    • Remove the fan cable by pulling the white connector away from you.
  44. Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector. Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
    • Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
  45. Carefully flip the laptop face-down with the battery compartment facing you. Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
    • Carefully flip the laptop face-down with the battery compartment facing you.
    • Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
  46. Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you. Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
    • Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
    • Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
  47. Locate the PC card below the SD card reader. Push the button to its left once to eject the button itself, then press it once again to remove the PC card. Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
    • Locate the PC card below the SD card reader.
    • Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
  48. Once the PC card pops out, pull it out.
    • Once the PC card pops out, pull it out.
  49. Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard. Push in the grey button to the left of the PC card as far as possible.
    • Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
    • Push in the grey button to the left of the PC card as far as possible.
    • Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
  50. Pull the right casing to the side to release the ports on the motherboard from it.
    • Pull the right casing to the side to release the ports on the motherboard from it.
  51. Lift the motherboard up until it releases from the bottom casing and remove it from the laptop. Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
    • Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
  52. Unscrew the two 4mm and one 2mm Phillips screws from the USB board. Unscrew the two 4mm and one 2mm Phillips screws from the USB board.
    • Unscrew the two 4mm and one 2mm Phillips screws from the USB board.
  53. Move the USB board out of the way and raise the right speaker unit up two inches.
    • Move the USB board out of the way and raise the right speaker unit up two inches.
  54. Pull out the black cable running along the left side of the right speaker unit to remove it. Pull out the black cable running along the left side of the right speaker unit to remove it. Pull out the black cable running along the left side of the right speaker unit to remove it.
    • Pull out the black cable running along the left side of the right speaker unit to remove it.
Abschluss
Allie Menard
769 Reputation
13 Anleitungen geschrieben
Cal Poly, Team 24-56, Amido Spring 2011 Mitglied von Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,667
