Zum Hauptinhalt wechseln
HP Pavilion ze4530US Keyboard Replacement
Was du brauchst
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion ze4530US Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: Schritt 6, Bild 1 von 1
    • You have successfully removed the keyboard.
Abschluss
Texas Tech, Team 38-5, Bennett Fall 2016 Mitglied von Texas Tech, Team 38-5, Bennett Fall 2016
TTU-BENNETT-F16S38G5
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 36
Insgesamt: 319
