Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide is designed to replace the battery of the device: HP Pavilion ze5000. A replacement of a battery should occur if the laptop stops charging or is dead and will not respond to the device's charger. This guide can be used in case a device user wants to check the quality of the battery or replace the battery with a new battery installation. When completing this guide, ensure that the device is properly faced down with the back of the laptop facing the device user.
  1. Push up on the arrow-shaped switch.
    • Push up on the arrow-shaped switch.
  2. While still holding the  switch up, remove the battery. While still holding the  switch up, remove the battery.
    • While still holding the switch up, remove the battery.
Abschluss
No reassembly in required once the new battery is in.
Gabrielle
97 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
2 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 75
