Zum Hauptinhalt wechseln
Einleitung
This guide will explain how to replace the keyboard of the device. The process should be rather simplistic but proceed with caution since some parts of the device are fragile.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two  5mm Phillips #0 screws from the hinges Remove the two  5mm Phillips #0 screws from the hinges Remove the two  5mm Phillips #0 screws from the hinges
    • Remove the two 5mm Phillips #0 screws from the hinges
  2. Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen Not much force is needed to pull the hinges off once the tweezers are properly positioned
    • Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen
    • Not much force is needed to pull the hinges off once the tweezers are properly positioned
  3. Remove the wire connection by gently pulling  on the fuse and connection itself. Do not pull on the wires, as this can remove the wires from the connection, destroying the fuse.
    • Remove the wire connection by gently pulling on the fuse and connection itself.
    • Do not pull on the wires, as this can remove the wires from the connection, destroying the fuse.
  4. Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame
    • Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame
  5. Gently lift the keyboard up from the frame so that you can see the  ribbon  still connected. Gently lift the keyboard up from the frame so that you can see the  ribbon  still connected.
    • Gently lift the keyboard up from the frame so that you can see the ribbon still connected.
  6. Remove the ribbon by  gently  pulling up the ends of the white receiver it is inserted in to. You may need to use tweezers for this part. During reassembly, when inserting the ribbon, you will hear a quiet, clicking sound when pushing down on the ends of the receiver.  Hearing this ensures the ribbon is in place.
    • Remove the ribbon by gently pulling up the ends of the white receiver it is inserted in to.
    • You may need to use tweezers for this part.
    • During reassembly, when inserting the ribbon, you will hear a quiet, clicking sound when pushing down on the ends of the receiver. Hearing this ensures the ribbon is in place.
Abschluss
To reassemble your device, follow these instructions in reverse order starting at step 5.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Eric Beaudry
787 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 89
