Einleitung
This guide will explain how to replace the primary fans of the device. There is another fan located in the northern section of the interior of the device that this repair guide will not cover. This guide deals with the more involved sections of the device.
Was du brauchst
Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen
Remove the wire connection by gently pulling on the fuse and connection itself.
Gently lift the keyboard up from the frame so that you can see the ribbon still connected.
Remove the ribbon by gently pulling up the ends of the white receiver it is inserted in to.
Remove sixteen 5.0 mm Phillips #1 screws from the underside of the device
Remove the additional four 5.0 mm Phillips #1 screws from the hinge of the device
Remove the two 4.0 mm Phillips #0 screws attached to the cicuit board above the keyboard
Take the circuit board off by pulling up on the right side of the circuit board
Disconnect the ribbons from the circuit board underneath the keyboard housing unit
Remove the latches securing the fan housing unit by unscrewing the six 4.0 mm Phillips #0 screws
Lift the housing unit a few inches from the device to expose the two small connections.
Remove the two small connections directly above and below the fan housing unit
2 weitere Nutzer:innen haben diese Anleitung absolviert.
