Einleitung
This guide will explain how to replace the screen, assuming none of the electric connections have been damaged and the screen is the only damaged part. Some of the inner parts have sharp, metal corner and minor injury can occur if you rush through the guide.
Ersatzteile
Keine Ersatzteile angegeben.
Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
