Zum Hauptinhalt wechseln
HP Pavilion zv5000 Hard Drive Replacement
Was du brauchst
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion zv5000 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion zv5000 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion zv5000 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Eliza Marks
649 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-6, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Mitglieder
Ein Kommentar
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 2,880
