Einleitung
Are you having issues saving files to your computer? Have you already tried deleting unwanted files? Replacing the hard drive may solve these issues.
Was du brauchst
Make sure that your device is properly shut down and unplugged from any outlet.
Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
Press and slide up the battery release tab with your thumb until the battery pops out of place.
Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
Completely remove the hard drive from its socket.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
