Einleitung
Are you having trouble seeing anything on your screen? Is your screen perpetually black, even when plugged in and charged? If so, replacing your screen may bring visuals back to your life.
Was du brauchst
Make sure that your device is properly shut down and unplugged from any outlet.
Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
Press and slide up the battery release tab with your thumb until the battery pops out of place.
Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
Using the same Phillips #0 screwdriver, unscrew the six Phillips PM 2.5X6.0mm screws.
Also remove the four Phillips PM 2.5X13.0mm screws to remove the thermal plate with the same screwdriver.
Flip the laptop back over and open the lid all the way.
Using the flat edge of the plastic spudger, pry straight up to remove the Mini PCI Connector Cables from the board.
Using the tweezers, gently squeeze and pull backwards on the display cable until it is disconnected.
Use the Phillips #0 screwdriver again to remove the four Phillips 2.5X13.0mm screws that hold the clips for the screen into place.
Turn the laptop around until the top cover is facing you. Keep the laptop in an open position.
Unscrew the four Phillips PM 2.5X6.0mm screws using the Phillips #0 that hold the clips of the screen on to the base.
Firmly grasp the top of the screen with your hands and pull towards you and upwards to remove the screen from the base.
2 weitere Personen haben diese Anleitung absolviert.
