Zum Hauptinhalt wechseln
HP Pavillion G7-2235DX Keyboard Replacement
Was du brauchst
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 2, Bild 1 von 1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 3, Bild 1 von 2 HP Pavillion G7-2235DX Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Pavillion G7-2235DX Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-7, Leahy Fall 2016 Mitglied von USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 72
Insgesamt: 3,680
