Zum Hauptinhalt wechseln
HP Pavillion dm4t-2100 Hard Drive
Was du brauchst
  1. HP Pavillion dm4t-2100 Hard Drive, Battery: Schritt 1, Bild 1 von 2 HP Pavillion dm4t-2100 Hard Drive, Battery: Schritt 1, Bild 2 von 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Pavillion dm4t-2100 Hard Drive: Schritt 2, Bild 1 von 3 HP Pavillion dm4t-2100 Hard Drive: Schritt 2, Bild 2 von 3 HP Pavillion dm4t-2100 Hard Drive: Schritt 2, Bild 3 von 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
    Frag FixBot
  3. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: Schritt 3, Bild 1 von 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: Schritt 3, Bild 2 von 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: Schritt 3, Bild 3 von 3
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
    Frag FixBot
  4. HP Pavillion dm4t-2100 Hard Drive: Schritt 4, Bild 1 von 3 HP Pavillion dm4t-2100 Hard Drive: Schritt 4, Bild 2 von 3 HP Pavillion dm4t-2100 Hard Drive: Schritt 4, Bild 3 von 3
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
    Frag FixBot
  5. HP Pavillion dm4t-2100 Hard Drive: Schritt 5, Bild 1 von 1
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 656
