Einleitung
To detach the memory you will need a Phillips PH1 screwdriver. Also remember to be gentle with the screws because not all of them will completely detach from the plastic.
Was du brauchst
Shut down the computer.
Turn computer upside down so the base is facing upward.
Slide latch next to battery icon until battery pops up.
Pull the battery away from the computer until completely detached.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
Lift black cover overlaying memory chip.
Spread the tabs on each side of the memory slot to release the module.
Remove memory by pulling the memory out at an angle, until completely detached.
