Zum Hauptinhalt wechseln
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: Schritt 1, Bild 1 von 2 HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: Schritt 1, Bild 2 von 2
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: Schritt 2, Bild 1 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 2, Bild 2 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 2, Bild 3 von 3
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: Schritt 3, Bild 1 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 3, Bild 2 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 3, Bild 3 von 3
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: Schritt 4, Bild 1 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 4, Bild 2 von 3 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 4, Bild 3 von 3
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: Schritt 5, Bild 1 von 2 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 5, Bild 2 von 2
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: Schritt 6, Bild 1 von 2 HP Photosmart C4435 Ink Cartridge Replacement: Schritt 6, Bild 2 von 2
    • Close the ink compartment before using the printer.
Ziellinie
Kalvin Trac
133 Reputation
1 Anleitung geschrieben
York University, Team 2-11, O'Regan Fall 2021 Mitglied von York University, Team 2-11, O'Regan Fall 2021
YORK-O'REGAN-F21S2G11
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 305
