Zum Hauptinhalt wechseln
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: Schritt 1, Bild 1 von 1
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: Schritt 2, Bild 1 von 2 HP Photosmart D110a Ink Cartridge Replacement: Schritt 2, Bild 2 von 2
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: Schritt 3, Bild 1 von 1
    • Place the new cartridge into the slot and press firmly until it pops into place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tim Wise
173 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 10-38, Forte Spring 2011 Mitglied von Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Antwort
the HP ink cartridge is 60. Does that make any difference???
April -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 37
Insgesamt: 11,854
