Zum Hauptinhalt wechseln
HP Photosmart D110a Power Button Replacement
Was du brauchst
  1. HP Photosmart D110a Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: Schritt 3, Bild 1 von 3 HP Photosmart D110a Power Button Replacement: Schritt 3, Bild 2 von 3 HP Photosmart D110a Power Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: Schritt 4, Bild 1 von 1
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: Schritt 5, Bild 1 von 1
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: Schritt 6, Bild 1 von 3 HP Photosmart D110a Power Button Replacement: Schritt 6, Bild 2 von 3 HP Photosmart D110a Power Button Replacement: Schritt 6, Bild 3 von 3
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: Schritt 7, Bild 1 von 3 HP Photosmart D110a Power Button Replacement: Schritt 7, Bild 2 von 3 HP Photosmart D110a Power Button Replacement: Schritt 7, Bild 3 von 3
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tim Wise
173 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 10-38, Forte Spring 2011 Mitglied von Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 3,517
