Zum Hauptinhalt wechseln
HP Photosmart Premium C309g Scanner Replacement
Was du brauchst
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: Schritt 1, Bild 1 von 1
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Replacement: Schritt 2, Bild 1 von 2 HP Photosmart Premium C309g Scanner Replacement: Schritt 2, Bild 2 von 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Replacement: Schritt 3, Bild 1 von 2 HP Photosmart Premium C309g Scanner Replacement: Schritt 3, Bild 2 von 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Replacement: Schritt 4, Bild 1 von 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Replacement: Schritt 5, Bild 1 von 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Replacement: Schritt 6, Bild 1 von 1
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g Scanner Replacement: Schritt 7, Bild 1 von 2 HP Photosmart Premium C309g Scanner Replacement: Schritt 7, Bild 2 von 2
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
  8. HP Photosmart Premium C309g Scanner Replacement: Schritt 8, Bild 1 von 2 HP Photosmart Premium C309g Scanner Replacement: Schritt 8, Bild 2 von 2
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
Abschluss
Charles
371 Reputation
2 Anleitungen geschrieben
Michigan Tech, Team 1-2, Lauer Fall 2014 Mitglied von Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,349
