Zum Hauptinhalt wechseln
HP Prime Graphing Calculator G8X92A Button Panel Replacement
Was du brauchst
  1. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: Schritt 1, Bild 1 von 2 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 2, Bild 1 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 2, Bild 2 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 3, Bild 1 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 3, Bild 2 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: Schritt 4, Bild 1 von 2 HP Prime Graphing Calculator G8X92A Button Panel Replacement, Button Panel: Schritt 4, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 5, Bild 1 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 5, Bild 2 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 5, Bild 3 von 3
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 6, Bild 1 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 6, Bild 2 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 6, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 7, Bild 1 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 7, Bild 2 von 3 HP Prime Graphing Calculator G8X92A Button Panel Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 1,026
