Einleitung
If your computer is always over heating due to the fan not properly cooling down the internal components, then you may need to replace the fan. The fan allows for air circulation throughout the computer.
Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
Disconnect the red, black, and blue ribbon cable connector using the black spudger.
3 weitere Personen haben diese Anleitung absolviert.
