Zum Hauptinhalt wechseln
HP ProBook 4320t Keyboard Replacement Guide
Was du brauchst
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: Schritt 1, Bild 1 von 2 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: Schritt 2, Bild 1 von 2 HP ProBook 4320t Keyboard Replacement Guide, Screws: Schritt 2, Bild 2 von 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: Schritt 3, Bild 1 von 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: Schritt 4, Bild 1 von 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: Schritt 5, Bild 1 von 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: Schritt 6, Bild 1 von 2 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: Schritt 6, Bild 2 von 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: Schritt 7, Bild 1 von 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Abschluss
Joshua
134 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 9-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 40
Insgesamt: 1,206
