Einleitung
The power button panel is one of the easiest components to replace on th HP 4320t. It may need replaceing, if damaged, to insure proper working order.
Was du brauchst
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
Slightly push up while lifting up on the power button panel to release the panel.
3 weitere Personen haben diese Anleitung absolviert.
