Einleitung
If the touch pad becomes damaged it will need to be replaced in order for it to properly work. There are a good amount of steps in this process but, it is not too difficult.
  1. Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in. Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver). Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. Flip laptop over and open it.
    • Flip laptop over and open it.
  4. Slightly push up while lifting up on the power button panel to release the panel.
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Carefully (holding both sides of the keyboard), push up and lift slightly. Keyboard is still connected via a ribbon cable.
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  8. Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  9. Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  10. Carefully slide the bottom panel to the right.
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  11. Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  12. Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  13. Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
    • Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
  14. Slightly push the touch pad retention panel forward to remove from clasp and lift up.
    • Slightly push the touch pad retention panel forward to remove from clasp and lift up.
  15. Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
    • Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
  16. Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
    • Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
Abschluss
Joshua
88 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 9-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 680
