Zum Hauptinhalt wechseln
HP ProBook 4320t Wi-Fi Card Replacement Guide
Was du brauchst
  1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: Schritt 1, Bild 1 von 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: Schritt 2, Bild 1 von 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: Schritt 2, Bild 2 von 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Flip: Schritt 3, Bild 1 von 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Push N Lift: Schritt 4, Bild 1 von 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrewing: Schritt 5, Bild 1 von 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: Schritt 6, Bild 1 von 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: Schritt 6, Bild 2 von 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: Schritt 7, Bild 1 von 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrew: Schritt 8, Bild 1 von 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Wi-Fi Card Replacement Guide, Slide the Panel Off: Schritt 9, Bild 1 von 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Wi-Fi Card Replacement Guide, Lift up Carefully: Schritt 10, Bild 1 von 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: Schritt 11, Bild 1 von 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Wi-Fi Card Replacement Guide, Wi-Fi Card: Schritt 12, Bild 1 von 1
    • Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
    • Be careful not to break the cords.
  13. HP ProBook 4320t Wi-Fi Card Replacement Guide: Schritt 13, Bild 1 von 1
    • Unscrew the two (2.5 mm Phillips) screws holding the wifi card in.
    • Be careful because upon the last turn of the screw, the Wi-Fi card lifts up slightly.
  14. HP ProBook 4320t Wi-Fi Card Replacement Guide: Schritt 14, Bild 1 von 1
    • Pull the Wi-Fi card towards the left to remove.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Joshua
134 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 9-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 639
