Zum Hauptinhalt wechseln
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
Was du brauchst
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: Schritt 1, Bild 1 von 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 2, Bild 1 von 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: Schritt 3, Bild 1 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: Schritt 3, Bild 2 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: Schritt 3, Bild 3 von 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 4, Bild 1 von 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): Schritt 5, Bild 1 von 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): Schritt 5, Bild 2 von 2
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 6, Bild 1 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 6, Bild 2 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 6, Bild 3 von 3
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 7, Bild 1 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 7, Bild 2 von 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 7, Bild 3 von 3
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 8, Bild 1 von 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: Schritt 8, Bild 2 von 2
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 75
Insgesamt: 4,224
