Einleitung
This guide will tell you how to replace the hard drive for HP ProBook 450 G3.
Was du brauchst
Unscrew the 2.5 mm screw with PH00 screwdriver.
Pull the cover off the computer using two hands.
Unscrew the all four 2.5 mm screws with the PH00 screwdriver.
Then carefully pull to the right the hard-drive. It should release from its container.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
