Einleitung
This guide will tell you how to replace the optical drive for the HP ProBook 450 G3.
Was du brauchst
Remove the 2.5 torx screw.
Pivot the spudger between the hard-drive and the optical drive. Push the optical drive away from the center of the computer.
Using the spudger carefully place the pointed end into the gap that covers the optical drive.
Fast fertig!
Abschluss
