Zum Hauptinhalt wechseln
HP ProBook 450 G4 Display Assembly Replacement
Was du brauchst
  1. HP ProBook 450 G4 Display Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP ProBook 450 G4 Display Assembly Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off your laptop and flip it over so that the bottom faces upward.
    • Use the Phillips #0 screwdriver to remove the screw securing the service door.
    • Use a Jimmy to remove the service door.
  2. HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: Schritt 2, Bild 1 von 2 HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
    • Remove the black 3.2mm screw that secures the hard drive to the left side of the laptop with a Phillips #0 screwdriver.
    • Use the spudger to lift the left side of the hard drive, and remove.
  3. HP ProBook 450 G4 Display Assembly Replacement: Schritt 3, Bild 1 von 2 HP ProBook 450 G4 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove all 6.6 mm T8 Torx screws, including where the hard drive used to be.
  4. HP ProBook 450 G4 Display Assembly Replacement: Schritt 4, Bild 1 von 2 HP ProBook 450 G4 Display Assembly Replacement: Schritt 4, Bild 2 von 2
    • Unclip the wires from the Wi-Fi card.
    • Remove the Wi-Fi card.
  5. HP ProBook 450 G4 Display Assembly Replacement: Schritt 5, Bild 1 von 3 HP ProBook 450 G4 Display Assembly Replacement: Schritt 5, Bild 2 von 3 HP ProBook 450 G4 Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Flip the laptop over, and use a Jimmy to loosen the keypad from the laptop.
    • Use the spudger to unclip the tab.
    • Remove the top case once all tabs are loose.
  6. HP ProBook 450 G4 Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Use the spudger to disconnect the black wire.
  7. HP ProBook 450 G4 Display Assembly Replacement: Schritt 7, Bild 1 von 2 HP ProBook 450 G4 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws from the hinges.
    • Repeat on both sides.
  8. HP ProBook 450 G4 Display Assembly Replacement: Schritt 8, Bild 1 von 1
    • Remove and replace the display assembly.
Abschluss
Nat Robinson
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 43
