Zum Hauptinhalt wechseln
HP ProBook 450 G4 Touch Pad Replacement
Was du brauchst
  1. HP ProBook 450 G4 Touch Pad Replacement, Hard Drive: Schritt 1, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Touch Pad Replacement: Schritt 2, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 2, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Touch Pad Replacement: Schritt 3, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Touch Pad Replacement: Schritt 4, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement: Schritt 4, Bild 2 von 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Touch Pad Replacement, Keyboard: Schritt 5, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement, Keyboard: Schritt 5, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Touch Pad Replacement: Schritt 6, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 6, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Touch Pad Replacement: Schritt 7, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 7, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 7, Bild 3 von 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Touch Pad Replacement: Schritt 8, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Touch Pad Replacement, Touch Pad: Schritt 9, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement, Touch Pad: Schritt 9, Bild 2 von 2
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6 mm screws underneath where the keyboard used to be using a T8 Torx screwdriver.
  10. HP ProBook 450 G4 Touch Pad Replacement: Schritt 10, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 10, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 10, Bild 3 von 3
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  11. HP ProBook 450 G4 Touch Pad Replacement: Schritt 11, Bild 1 von 2 HP ProBook 450 G4 Touch Pad Replacement: Schritt 11, Bild 2 von 2
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the case comes off.
    • Remove the top case.
  12. HP ProBook 450 G4 Touch Pad Replacement: Schritt 12, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 12, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 12, Bild 3 von 3
    • Flip the top cover over.
    • Use the spudger to disconnect the cable connector labeled TP.
    • Be extra careful while disconnecting the cable connector because it can tear easily.
  13. HP ProBook 450 G4 Touch Pad Replacement: Schritt 13, Bild 1 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 13, Bild 2 von 3 HP ProBook 450 G4 Touch Pad Replacement: Schritt 13, Bild 3 von 3
    • Remove the four M2 1.9 mm screws holding the touchpad down.
    • Lift the touchpad up and out from the top.
Abschluss
Maddy Johnson
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 50
