Zum Hauptinhalt wechseln
HP ProBook 4520s Screen Replacement
Was du brauchst
  1. HP ProBook 4520s Screen Replacement, Battery: Schritt 1, Bild 1 von 2 HP ProBook 4520s Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Screen Replacement, Switch Cover: Schritt 3, Bild 1 von 2 HP ProBook 4520s Screen Replacement, Switch Cover: Schritt 3, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Screen Replacement: Schritt 4, Bild 1 von 2 HP ProBook 4520s Screen Replacement: Schritt 4, Bild 2 von 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Screen Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Screen Replacement: Schritt 6, Bild 1 von 3 HP ProBook 4520s Screen Replacement: Schritt 6, Bild 2 von 3 HP ProBook 4520s Screen Replacement: Schritt 6, Bild 3 von 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Screen Replacement, Screen: Schritt 7, Bild 1 von 2 HP ProBook 4520s Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
  8. HP ProBook 4520s Screen Replacement: Schritt 8, Bild 1 von 2 HP ProBook 4520s Screen Replacement: Schritt 8, Bild 2 von 2
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
  9. HP ProBook 4520s Screen Replacement: Schritt 9, Bild 1 von 3 HP ProBook 4520s Screen Replacement: Schritt 9, Bild 2 von 3 HP ProBook 4520s Screen Replacement: Schritt 9, Bild 3 von 3
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
  10. HP ProBook 4520s Screen Replacement: Schritt 10, Bild 1 von 2 HP ProBook 4520s Screen Replacement: Schritt 10, Bild 2 von 2
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
  11. HP ProBook 4520s Screen Replacement: Schritt 11, Bild 1 von 1
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
  12. HP ProBook 4520s Screen Replacement: Schritt 12, Bild 1 von 1
    • Gently push the back cover away.
  13. HP ProBook 4520s Screen Replacement: Schritt 13, Bild 1 von 3 HP ProBook 4520s Screen Replacement: Schritt 13, Bild 2 von 3 HP ProBook 4520s Screen Replacement: Schritt 13, Bild 3 von 3
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
  14. HP ProBook 4520s Screen Replacement: Schritt 14, Bild 1 von 3 HP ProBook 4520s Screen Replacement: Schritt 14, Bild 2 von 3 HP ProBook 4520s Screen Replacement: Schritt 14, Bild 3 von 3
    • Peel the ribbon cable away from the screen.
  15. HP ProBook 4520s Screen Replacement: Schritt 15, Bild 1 von 2 HP ProBook 4520s Screen Replacement: Schritt 15, Bild 2 von 2
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team 1-3, Oliver Fall 2016 Mitglied von UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
I need back cover hp i5 probook 4520s
amir86216 - Antwort
I need speakers hp probook 4520s i5
Osagie Rmd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 6,100
