Zum Hauptinhalt wechseln
HP ProBook 4530s WiFi Card Replacement
Was du brauchst
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: Schritt 1, Bild 1 von 2 HP ProBook 4530s WiFi Card Replacement, Introduction: Schritt 1, Bild 2 von 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: Schritt 2, Bild 1 von 1
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: Schritt 3, Bild 1 von 1
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: Schritt 4, Bild 1 von 2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: Schritt 4, Bild 2 von 2
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: Schritt 5, Bild 1 von 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: Schritt 5, Bild 2 von 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: Schritt 5, Bild 3 von 3
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Drew Canada
1.370 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 35
Insgesamt: 3,569
