Einleitung
Removing the bottom door is necessary to reach most of the other components of the laptop. Replacing the bottom door may be necessary if there are excessive dents and scratches which can potentially harm internal components.
Was du brauchst
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Turn the computer so the bottom is facing towards you.
Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
