Zum Hauptinhalt wechseln
HP ProBook 4540s Optical Drive Replacement
Was du brauchst
  1. HP ProBook 4540s Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: Schritt 2, Bild 1 von 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: Schritt 3, Bild 1 von 2 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: Schritt 3, Bild 2 von 2
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
  4. HP ProBook 4540s Optical Drive Replacement: Schritt 4, Bild 1 von 2 HP ProBook 4540s Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Amber Schindler
1.027 Reputation
6 Anleitungen geschrieben
UW Tacoma, Team 1-5, Rose Fall 2016 Mitglied von UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 2,333
