Einleitung
The WLAN module is used to power the Wi-Fi on the ProBook; not to be confused with the WWAN module that powers mobile broadband. The two modules are beside each other but the smaller module is WLAN which will be the focus for this guide.
Was du brauchst
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Turn the computer so the bottom is facing towards you.
Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
Disconnect the antenna cables from their terminals in the WLAN module.
Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
Gently lift and remove the module.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
