Zum Hauptinhalt wechseln
Einleitung
If your battery is not working, needs to cool down, or needs to be taken out for another reason, follow the steps below to remove it properly.
  1. Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  3. Slide the two battery release latches towards the center of the laptop to release the battery.
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  4. Tilt the battery upward. Remove it from the laptop.
    • Tilt the battery upward.
    • Remove it from the laptop.
Abschluss
Jennifer Sexton
552 Reputation
4 Anleitungen geschrieben
Baylor, Team S5-G1, Williams Spring 2018 Mitglied von Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 251
