Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Your computer’s service panel may become damaged after prolonged use or age. One of the ways you can fix this is by replacing the panel itself.
  1. Slide the two release latches that were mentioned in the battery removal process to release the service panel.
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  2. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  3. Slide the service panel toward you using your thumbs. Lift it to remove the panel and reveal inner components of the computer.
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
Abschluss
Jennifer Sexton
583 Reputation
4 Anleitungen geschrieben
Baylor, Team S5-G1, Williams Spring 2018 Mitglied von Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 7
Insgesamt: 321
