Was du brauchst
Remove the two screws at the two indicated locations with the phillips head screw driver.
Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
3 weitere Personen haben diese Anleitung absolviert.
