Einleitung
The maximum dimensions of a new solid state drive are 100.5 x 69.85 x 7.0mm. Before performing any work, always remember to completely turn off and disconnect your computer from any power source.
Was du brauchst
Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
Pull up on the hard drive bay handle and push it to the left while holding back the metal tab on the bottom.
Remove the four 5/16" side screws, with the T15 Torx Screwdriver, and gently take out the drive.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
