Einleitung
The maximum dimensions of a new solid state drive are 100.5 x 69.85 x 7.0mm. Before performing any work, always remember to completely turn off and disconnect your computer from any power source.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up. Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
    • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
  2. Pull up on the hard drive bay handle and push it to the left while holding back the metal tab on the bottom.
    • Pull up on the hard drive bay handle and push it to the left while holding back the metal tab on the bottom.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Pull side latch out and slide the hard drive tray out of the bay.
    • Pull side latch out and slide the hard drive tray out of the bay.
  5. Remove the four 5/16" side screws, with the T15 Torx Screwdriver, and gently take out the drive. Remove the four 5/16" side screws, with the T15 Torx Screwdriver, and gently take out the drive.
    • Remove the four 5/16" side screws, with the T15 Torx Screwdriver, and gently take out the drive.
Abschluss
Angehängte Dateien
Janelle Layman
219 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-20, Maness Fall 2015 Mitglied von Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Mitglieder
12 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 1,786
