Einleitung
If your computer can no longer connect to a wireless network it may mean you have a broken Wi-Fi adapter. Before performing any work, always remember to completely turn off and disconnect your computer from any power source.
Was du brauchst
Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
Locate the Wi-Fi adapter at the top right corner of where the stand once was.
Unscrew the screws using the Philips #1 Screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
