Einleitung
One of the most frustrating things that can happen to your tablet is the inability for it to charge; the tablet is practically useless if you're unable to charge it. This guide will breakdown all the necessary steps to ensure that you're able to charge life into your tablet. In this guide, you will be removing the following:
- Back Cover
- Battery
- Charging Port
Prepare your required tools, a new charging port for your tablet, and set aside about 10 to 20 minutes to delve into the inner workings of your HP Slate.
Was du brauchst
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
Using the flat end of the spudger, lift up the black panel covering the charging port connector.
Gently slide the charging port ribbon out from its housing.
Push the white battery connector out of its housing using the pointed end of the spudger.
Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
Remove the screw with a #00 Phillips Head screwdriver.
34 weitere Personen haben diese Anleitung absolviert.
15 Kommentare
where do you get the replacement parts for charging port
Since HP does not supply the replacement ribbon, or many other parts for that matter, it is easiest to search on eBay and/or Craigslist for the parts needed. I found that the UK version of Amazon and eBay offer the best availability for such parts.
Zachary -
