Zum Hauptinhalt wechseln
HP Slate 7 4601 Motherboard Replacement
Was du brauchst
  1. HP Slate 7 4601 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
  2. HP Slate 7 4601 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
  3. HP Slate 7 4601 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
  4. HP Slate 7 4601 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the rear cover.
  5. HP Slate 7 4601 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Locate and remove the yellow tape covering the red and white speaker wires.
  6. HP Slate 7 4601 Motherboard Replacement: Schritt 6, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
  7. HP Slate 7 4601 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently pull back the foil covering the gold charging port ribbon.
  8. HP Slate 7 4601 Motherboard Replacement: Schritt 8, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Motherboard Replacement: Schritt 10, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Motherboard Replacement, Motherboard: Schritt 13, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement, Motherboard: Schritt 13, Bild 2 von 2
    • Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
    • When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
  14. HP Slate 7 4601 Motherboard Replacement: Schritt 14, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Likewise, disconnect the square radio chip ribbon by lifting up the black panel with a spudger and sliding the gold strip out.
  15. HP Slate 7 4601 Motherboard Replacement: Schritt 15, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • You will be using a #00 Phillips Head screwdriver to free the motherboard.
    • Remove the six 1.75mm x 3mm Phillips Head screws holding the motherboard to the screen.
  16. HP Slate 7 4601 Motherboard Replacement: Schritt 16, Bild 1 von 2 HP Slate 7 4601 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Using your hand, lift up the silver tape from the copper plate.
    • Lift the motherboard out of the device.
    • You may need to wiggle and work the motherboard to get it released from the device
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 13-30, Maness Spring 2014 Mitglied von Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
We have 7 inch Hp tablet please replace motherboard sir
Sushmitha - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 3,769
