Zum Hauptinhalt wechseln
HP Slate 7 Extreme 4400US Bottom Speaker Replacement
Was du brauchst
  1. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: Schritt 2, Bild 1 von 2 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: Schritt 2, Bild 2 von 2
    • Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
    • Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
  3. HP Slate 7 Extreme 4400US Bottom Speaker Replacement: Schritt 3, Bild 1 von 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: Schritt 3, Bild 2 von 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: Schritt 3, Bild 3 von 3
    • Locate where the speakers' wires are connected to the motherboard.
    • Using a pair of wire cutters, cut the wires connecting the speaker to the motherboard. Use a wire stripper to expose the wire to connect it with the wires of the new speaker.
    • You can also use a soldering tool to disconnect the wires from the motherboard and then connect the wires of the new speaker using the soldering tool.
Abschluss
Brandon Ko
698 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 11-4, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 131
