Einleitung
For this guide, you will need the following tools: plastic opening tool, spudger, PH 000 screw bit.
Was du brauchst
Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
Once all sides have been pried up, pull the cover off and place it to the side.
Pull back the tape holding the the camera's connector strip to the device.
Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
Gently pull the camera's connecting strip out from the port.
Eine weitere Person hat diese Anleitung absolviert.
