Was du brauchst
Turn off the tablet and disconnect the power and all external devices from the tablet.
Position the tablet with the display panel down and the right side toward you.
Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
Eine weitere Person hat diese Anleitung absolviert.
