Einleitung
This guide will show you how to pry open the screen and replace the front-facing camera.
Was du brauchst
Secure the suction cup to the center of the screen.
Using a plastic opening tool, pry along the edges of the display while pulling upwards with the suction cup.
Use the Spudger to disconnect the ribbon cable to the upper camera by prying the connector away from the board.
Use ESD safe tweezers to pry the camera away from the motherboard starting at the side opposite the ribbon cable.
