Zum Hauptinhalt wechseln
HP Spectre 13-4002dx Display Replacement
Was du brauchst
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: Schritt 1, Bild 1 von 3 HP Spectre 13-4002dx Display Replacement, Motherboard: Schritt 1, Bild 2 von 3 HP Spectre 13-4002dx Display Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: Schritt 2, Bild 1 von 1
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: Schritt 3, Bild 1 von 2 HP Spectre 13-4002dx Display Replacement: Schritt 3, Bild 2 von 2
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: Schritt 4, Bild 1 von 2 HP Spectre 13-4002dx Display Replacement: Schritt 4, Bild 2 von 2
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 445
