Zum Hauptinhalt wechseln
HP Spectre 13-4002dx Heat Sink Replacement
Was du brauchst
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: Schritt 1, Bild 1 von 2 HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: Schritt 2, Bild 1 von 2 HP Spectre 13-4002dx Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: Schritt 3, Bild 1 von 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: Schritt 3, Bild 2 von 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: Schritt 3, Bild 3 von 3
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: Schritt 4, Bild 1 von 2 HP Spectre 13-4002dx Heat Sink Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Remove the heat sink from the laptop.
Abschluss
Cayce Stewart
725 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 286
